shotgunFind
   1358   0   0
Continuation of the earlier post ,
unable to access the fields from shotgun Find node
gives me this error about encoding ?
tried this
import base64
cs = "http://user.shotgunstudio.com [user.shotgunstudio.com]"
cs64 = base64.b64encode(bytes(cs,'utf-8')) # this works
reckon i am missing something in the input values in the shotgunFind node ?
the network in tops is as below,
env edit with shotgun user name and password (cooks fine)
v
shotgun server begin (cooks fine)
v
shotgunFind # a bytes-like object is required, not ‘str’
could not find the answer to this, some reason its not encoding the string ?
Thanks,
