Dear Houdini Team,
if I enable “Render All Frames With a Single Process” in the USD Render Rop it discards any expressions I have in the rendersettings and only uses the first frame.
I want to switch between 45 cameras per frame ( light-field rendering ) with the expressions ( /Lightfield/cam_`$F%46` ). This is working fine until I activate the single process option which would speed up the rendering enormously though so I really wanted to get it working. When the single process option is enabled it only renders with the first camera.
Also, I tried using the flipbook rendering option ( because the scene initialization is even faster than the usd render rop ) but I could not manage to get the undistorted pixel per pixel beauty pass. It seems like the flipbook render files are dependent on the viewport.
It would be great getting your opinion on this and what you recommend as the fastest rendering option for rendering usd. Rendering with light fields will generate enormous amounts of frames, so scene initialization time reduction is absolutely crucial. Thank you very much!
Render All Frames With a Single Process - Problem
6808 8 2-
- spinori
- 15 posts
- jsmack
- 8221 posts
Can you create multiple render products, one for each camera to render with? I think some renderers will render a view for each render product.
Another option would be to render the lightfields in a single pass using a lens shader to create a photomosaic. Karma is the only renderer I know of that supports lens shaders in solaris at the moment though.
- spinori
- 15 posts
jsmack
Another option would be to render the light fields in a single pass using a lens shader to create a photomosaic. Karma is the only renderer I know of that supports lens shaders in Solaris at the moment though.
Wow, thank you very much these are both great ideas that I did not think would be possible. Especially the render product one. I use redshift for speed purposes, but I could also try Renderman or karma. I will do a set of tests tomorrow.
Edited by spinori - Dec. 7, 2020 19:18:50
- spinori
- 15 posts
jsmack
Did you succeed in creating a setup like this? Rendering multiple views via several render products? I am sorry to say that I am not 100 percent sure how to do that ^^. I was using render products for creating aov channels, but I never did a setup with multiple products in one rendersetting. Also with the lense shader: Have you succed doing something like this with any renderer? I know technically it is possible ( like doing a stereo renderer but with more views ). Thank you very much!
Edited by spinori - Dec. 8, 2020 08:24:47
- spinori
- 15 posts
- robp_sidefx
- 609 posts
- jsmack
- 8221 posts
- robp_sidefx
- 609 posts
- spinori
- 15 posts
robp_sidefxjsmackrobp_sidefxRendering multiple views via several render products?
This is not currently supported in husk, but it's on the radar.
Do you need RFE, or is it as you say "on the radar" already?
Internal RFEs already exist, all good
Thank you very much for the info! Looking forward to seeing something like this in future builds.
