Create polygon from edge group? Should be easy but...
   2328   3   1
Hi!
I am quite new with Houdini but this sounds so simple that I SHOULD be able to figure it out but so far not even close
I have an edge group that I want to turn to polygon(s) i.e. each connected loop would make a polygon. Those are flat so no problems like that but I cannot find a way to do it
There is probably some simple node that does it but I have tried many but none does what I need.
Labs Edge Group to Curve does what it says but I need Edge Group to Polygons node
I know it can be done in VEX but there must be simpler way with nodes only.
Please help me
Thank you!
Antti
Edited by atnreg - Dec. 9, 2020 08:56:12
My system:
AMD Ryzen Threadripper 2990 (32-core),64GB RAM,NVIDIA RTX 3090,Win10
UE5.1,Houdini 19.5 Indie(always latest daily),Blender,Clarisse,Onyx,ZBrush...
Clarisse 2016-09, Houdini 2018-05 (seriously 2019-10)
I do all 3D for fun, no business
Hey atnreg,
why not simply using a polyfill after the LABS edgegroup_to_curves node?
Cheers
CYTE
polyextrude ?
Hi!
Thank you CYTE, I knew there was some easy way and that is it! Works perfectly!
Vusta, polyextrude does it wrong way, I wanted to get the polygon from edge group that is the outline of the polygon.
Thank you both for your time!
Antti
My system:
