Iam using houdini 18.5.499. No matter which value I put in minimum percent available memory, 1 or 99, 0.1 or 0.9, the system still run out of memory and freeze my computer.
And if it isnt the correct way to prevent houdini using all the memory, is there any efficiency way to make houdini pdg using all the cpu but still limit the memory ?
localscheduler/minimum available memory, how to use ?
1619 0 0-
- forted.exe
- 14 posts
