Split string with empty entry VEX
   4671   4   2
I'm trying to split a string into an array by doing this:
s[]@turnlanes = split(s@turn_lanes,"|");
But it's not taking into account the fields that are left empty with just ||,
"left||" is split into just "left", where i would like it to insert "through" after each | and have it be split into "left,through,through".
How do I go about making this with vex?
Included file with OSM file, you might have to hook it up in the OSM Import.
Edited by stinzen - April 23, 2021 11:44:50
split_turnlanes.hiplc (103.9 KB)
Boston_SouthWaterfront_small.osm (1.7 MB)
use re_split() to get empty strings inbetween separator
if you also want empty string after the last separator you have to check for it individually
s[]@turnlanes_split= re_split(r"\|", s@turn_lanes);
if (endswith(s@turn_lanes, "|")) append(s[]@turnlanes_split, "");
this will give you
left|| -> [ left, "", "" ]
then you can replace those empty strings with "through" or whatever
Edited by tamte - April 23, 2021 18:52:40
Thank you tamte!
Now I'm trying to figure out how to replace the empty strings, the last one in the if statement is easy of cource but I don't know how to change both of them. I tried with re_findall and re_replace but I can't seem to get the syntax to work.
since it's an array now, just loop through it and if the string is empty replace with whatever
s[]@turnlanes_split = re_split(r"\|", s@turn_lanes);
foreach(int i; string lane; s[]@turnlanes_split){
    if (lane == "") s[]@turnlanes_split[i] = "through";
Edited by tamte - April 26, 2021 13:31:43
Thank you so much! I have to practice a bit more with arrays and loops.
