Ik flip stutter when animating Sofia.hda
   1440   1   0
I downloaded the Sofia character from the sidefx content library
to play around with a biped character rig.
When I did an animated test I noticed some stuttering with the arms.
What is causing this?
It would be nice if someone posted a "howto" tutorial on using Sofia.hda
The scene viewport interface is not very intuitive and saving keys isn't obvious.
there seems to be something wrong with the arm set key buttons in the Sofia UI
when I look at the curves in the animation editor the curve takes a hard drop at some frames
I have to select the curve segments and reset them to type bezier
then edit the key frames in the animation editor and run smooth selected slopes under edit pulldown(or 9 key)
something is broken in the set key scripts
Edited by WillA - April 30, 2021 20:47:07
