Working around the 4 input limitation for subNet
   2166   1   1
Hello, I am trying to figure out a modular design to connecting more then 4 inputs to a custom built subnet ( at the object level).
Just to be clear, so far my understanding of subnet is that you cannot add additional inputs ( unless they have been converted to hdas).
One possible solution at the object nodes, is that I have several null object ("markers" I use to get the position ), that I could
merge together as object to pass into one subnet input. However so far I have not found a working "object" level node to let me do this. I am playing with setting up my own object based hda, but it looks like even there I am limited to 10 inputs.
Alternatively, a nicer solution would be to have object level node that would take a single list input ( so I can plug N-inputs).
Any recommendations, hints, ideas on how to do this would be greatly appreciated.
Raffaele Scaduto-Mendola
turbolinea
I believe you can set it much higher than that, 10 is only the slider range
