Version of Houdini supported with Redshift 2.6.41
   5028   2   0
I was using Redshift 2.6.41 in a previous build of Houdini which I don't remember. Currently I have houdini-18.5.563 running on my Windows 10-64 bit system which does not run this version of Redshift. Which version of Houdini should I install ?
If you have redshift 2.6.41 installed you can see what versions the version of redshift supports by navigating to:
{redshift folder}Plugins\Houdini\
As far as i can see from a local install of 2.6.56, the max version of that build is 18.0.499.
Since 18.5.563 is so new i suspect that only the latest 3.0.45 will support this.
hope this helps.
Kym
kymwatts
hope this helps.
Kym
Thanks I got it! It supports till 17.5.229.
