Houdini and avast
   999   1   0
I'm not sure this is the right forum but I am having issues with Avast interfering with Houdini. I cannot start it if Avast is running, only if I disable the shield altogether. I added all the exes to exceptions, opened all the ports etc. yet it refuses to work, it keeps failing to connect to the server. Does anyone have any idea what to turn off in Avast in order to get it to work? I can always disable it, start Houdini and enable it again but it's quite annoying.
I managed to find the problem. My network was set to public instead of private, that fixed it for some reason (in case anyone else run into this)
