Python 3
   3254   2   2
I have two questions
1) how can i can update python 3.7.4 to the latest version
Houdini 18.5.596 installed python 3 as far as i can tell, i previously had only 2.7 installed on my pc. Does this mean python 3 is available only for Houdini? How can i update
2) How can i pip install packages to that directory? This has been a problem before and i had to change pip to install by default inside the houdini python directory. Before that i would copy the packages from the default directory in C:/Python27 to the Houdini one. Is this really that complicated or am i doing something wrong?
ideally i would like to have one place to store packages outside Houdini - the default directory that gets created when installing python on your computer. Just install python 3, pip install anything i need and have houdini use those.
I found answers in the following tutorial
except from "can i update python?"
https://www.youtube.com/watch?v=aUdC8p17QEc [www.youtube.com]
I don't think you can update Python in Houdini, cause all the libraries are compiled for that particular version already.
