Square Nurb with rounded corners?
   2169   3   1
Newbie of note. Trying to find a way to make a square / rectangle nurb with adjustable rounded corners that I can use to extrude.
I have searched around and can't seem to find anything.
My best solution is to import a adobe illustrator path... but I can't get the corners to be adjusted that way...
Any advice greatly appreciated!
Thank you!
Maybe it Helps.
vector dirprev = point(0, "P", (@ptnum + @numpt -1) % @numpt)  - @P;
vector dirnext = point(0, "P", (@ptnum +1) % @numpt) - @P;
@dot = dot(normalize(dirprev),normalize(dirnext));
@rad = degrees(acos(@dot));
LibOdforce.hiplc (112.6 KB)
Conservation of Momentum
Hello
You can also use fillet node in sop to build round corner with nurbs
check the file
But also Nurbs isn't really developed in Houdini
the best would be to use the polygon approach with a square and polybevel the point
Edited by Benjamin Lemoine - Sept. 5, 2021 05:59:21
fillet.hiplc (139.9 KB)
Thank you so much Benjamin Lemoine and cncverkstad I really appreciate the help!
Have an awesome week!
