Hi. We're evaluating Houdini for Unreal and everything went well until now. Whenever I reimport and recook an HDA I get this error:
"Cook Results:
HAPI Error: The node is invalid. Either the otl/hda asset library file was deleted or another otl/hda asset library file was loaded that contained an operator type with the same name as this asset's operator type. You must unload this node's asset and re-instantiate it.
Cook State:
Ready with Fatal Errors - Evaluating python"
If I delete the instance in the scene and make a new instance it works like it should. Any ideas appreciated.
Windows, Houdini 18.5.696, Unreal 4.27 and latest houdini engine for 18.5.696/4.27.
Reimporting/recooking an HDA: "The node is invalid"
2730 3 0-
- onetrickunicorn
- 3 posts
- onetrickunicorn
- 3 posts
Or, mostly I get:
"Cook Results:
Invalid argument given: Invalid id.
Cook State:
Ready with Fatal Errors"
When I create an instance of an HDA in a scene, everything works until I reimport and recook, without fail. I'm a bit stuck just trying to get past this, it's almost impossible get any work done.
This is V2. Happens in my main scene, but I tried it in a new scene, same thing.
"Cook Results:
Cook State:
- onetrickunicorn
- 3 posts
- indigosm
- 75 posts
