i have 2 line segments ( with multiple points ) . i want to match the shape of line1(source) to line2(target).
so i calculate the vector between pt1 and pt0 and use a dihedral to rotate the source line to match the target.
it works in a test about the origin.... but when they are out in world space it doesnt quite work.
ps : new to matrices in houdini.
here is a simple test
ps2: what i eventually want to do is match target's shape to source, segment by segment so the illusion of unrolling
matrix math help : aligning 2 vectors using dihedral
1227 3 1-
- carthick
- 28 posts
- toadstorm
- 406 posts
When you're doing anything involving rotations, you need to keep the pivot in mind. If you're just multiplying points by a 3x3 matrix, the assumption is that you're rotating about the origin. If that's not what you want, what you need to do is subtract some value from P so that the point you want to rotate around is at the origin, then multiply by your matrix, then add that same value you subtracted back to P.
- carthick
- 28 posts
- toadstorm
- 406 posts
You could go about it that way if you wanted, but really it's probably easier to just subtract some value V from P so that your pivot lies at the origin, then multiply P by your 3x3, then add V back to P and you're done. The exact value for V depends on what you want to rotate around.
