Filename Wild Card Syntax
   2327   2   1
Hey folks. Trying to load in a file using wildcards in the path name but it doesn't seem to work.
$OS/folder/*name*.*
What's the easiest way to do this in Houdini?
Hello
In PDG you can do this kind of loading with file pattern node.
Then process everything as you want in another node...
You could also use $F instead of *. This way you can process objects according to the timeline.
Cheers
CYTE
