viewport near Clipping plane
   1811   2   2
one of those problems, where it´s not easy to reproduce, so I was wondering, if anyone else has the same problem. As my scene gets more complex, my viewport near clipping plane starts autoadjusting to strange values, like 140 meters.
In version 18.5 and earlier, while the near clipping plane was often giving me trouble, it was mostly enough to recenter the view using SPACE + Z, or if it was getting really bad, just turn off autoadjust near Clipping Plane in display properties, setting it to 0.001 manually.
19.0.383 is a different beast completely though. It just started to auto-set my Near Clipping plane to values around 140m, making it absolutely impossible to work on anything close up. But the worst thing is, turning off the Autoadjust Near Clipping plane seem to last only until I first start navigating the viewport again, at which point it jumps back to some insane unusable value (overwriting my manual setting). In the display properties, the setting is stil editable by the user though, as though it was set to manual setting.
If anyone has a solution to this, you´ll make me very happy.
Ivan
did you find a solution for this?
Hi, sorry, I haven't been using Houdini that often in the past few months, so I can't say, if it's still a problem in 19.5 or how to solve it.
