Grid disappearing when viewport is below certain angle - H19
3871
4
1
frig2
Jan. 8, 2022 10:22 a.m.
I've attached a video showing the issue better than I could explain - has anyone encountered this before? Seems to have been an issue ever since I upgraded to H19. Doesn't happen at all on my 18.5 install.
I'm on daily builds H19.
VIDEO
Edited by frig2 - Jan. 8, 2022 10:22:52
Ryzen 9 5950x - RTX A5000 - 64GB RAM
J_Friggens
Jan. 26, 2022 9:38 a.m.
Hi, I have also had this issue ! As a fix (that worked for me), head to display options by pressing the D key with your cursor over the viewport. head to the "camera" tab. In the "clipping" sectionm, change the "homing auto adjusts" parameter to "far clip plane only". Cheers
Edited by J_Friggens - Jan. 26, 2022 12:53:10
Indushka
Feb. 1, 2022 6:23 p.m.
J_Friggens, Thanks a lot! I've been fighting this for a couple of months too and almost put up with this. This trick helped.
frig2
Feb. 2, 2022 9:08 p.m.
J_Friggens Hi, I have also had this issue ! As a fix (that worked for me), head to display options by pressing the D key with your cursor over the viewport. head to the "camera" tab. In the "clipping" sectionm, change the "homing auto adjusts" parameter to "far clip plane only". CheersThanks, J_Friggens, this fixed the issue indeed! Much appreciated!
AhmedHindy
March 17, 2022 4:50 p.m.
the solution here disables near clipping, is there another solution that doesn't compromise on such useful feature?
