Does anyone know how to export/cache an alembic (or USD) groom from Houdini 19 so that it retains the UV attribute and then bring that back into Solaris? For some reason when I import into solaris I lose the UV attribute. Other attributes seem to work but when I try to assign a texture it doesn't work
I also tried bringing it as an SOP import, however I'm trying to avoid that as I'll need to cache the groom out (the SPO had a separate issue I encountered)
Losing UV attribute on groom export
1751 0 0-
- Milen Piskuliyski
- 17 posts
