The Houdini 19.0 Apple Silicon build is a technical preview providing early access for macOS users on Apple M1 hardware. You can post feedback and bug submit reports specific to the Apple Silicon build in the forum. Please review the information below before posting.
NOTE: The Houdini 19.0 Apple Silicon build is not production ready and is not supported by SideFX for production use.
Downloading the Apple Silicon Build
- On the SideFX website, go to Get -> Download in the main menu bar at the top of the page. You need to login first before accessing the download page.
- Scroll to the bottom of the download page and click on the DAILY BUILDS button.
- On the Daily Builds download page, make sure that you are viewing the old installer builds and not the launcher builds. If the green button at the top of the page says Switch to old installer, then click on it to view the old installer builds.
- At the top of the page, select the Show All button.
- Scroll to the bottom of the Houdini 19.0 section. There will be a subsection titled Apple Silicon Builds Tech Preview with the latest Apple Silicon daily builds.
Submitting Bug Reports
- Do not submit Apple Silicon bugs to SideFX Support. The Apple Silicon build is a technical preview and is not production ready and is not supported for production use. SideFX Support will not respond to Apple Silicon bug reports.
- Review the Known Limitations and Bugs section below before submitting a bug to check if the bug is already a known issue.
- Verify that the bug is specific to the Apple Silicon build and is not a general Houdini or macOS bug. To verify, test if the bug exists in the main Houdini macOS x86_64 build. General Houdini and macOS bugs should be submitted to SideFX Support.
- Post a new topic in this forum to report the bug along with test steps and any supporting files needed to reproduce the bug.
- No Houdini Launcher support.
- No HQueue support.
- No Houdini Engine plugin support.
- No Karma XPU support.
- No 3D Connexion support.
- Performance regressions in various SOP operators (i.e. UVFlatten, etc.).
- Performance regression in Pyro.
- Minor regressions in COPs, SOPs and DOPs.
