Houdini rendering error code: command exit code: -1073741819
   7118   1   1
I recently had a bug with Houdini rendering, it would render 5 or 10 frames and then give me the error, which is so annoying
Has anyone found a cause or solution? thank you very much
This is an Access Violation exception. It is a very general error, so it could be many things, but commonly is caused by references to missing or wrong geometry/files/parameters, missing plugins.
If this is happening on your render farm, you could try locally performing a command-line render to obtain a stack trace, which could be used to investigate further.
