Boolean operations and large number of points.
2488 1 0-
- IR_Erik_Lycke_98
- 1 posts
- Digipiction
- 166 posts
I would not use booleans for this, there's a much faster way. You can create it in 2D first, i.e. you duplicate a bunch of circles and put a rectangle around them. Make sure that the circles and the rectangle all lie on the same plane, for example all on Y position 0.
Merge all of these 2D geometries together and follow up with a Hole SOP to generate the polygon with holes in it. Then you can extrude the polygon.
Another option might be to use a shader with an opacity texture instead of doing it as full geometry.
Edited by Digipiction - March 25, 2022 20:39:57
