456.py doc clarifcation and proper occurance locations
   1767   1   1
hello, i'm taking a look at 456.py based on my logging. 456.py is called alot
the documetion is alittle unclear "Houdini runs this script whenever a scene file is loaded (including when Houdini starts up with a scene file)." the world "only" is missing. thus its unclear if this behavour is correct:
if i open without a scene file, 123 is called THEN 456 is called.
if i go click on "file:new": i get 456.py run NOT 123.py
if i click "file, open some scene" i get 123 and then 456.py.
thank you for any help. or clarfication.
Seeing this same behavior in Houdini 19.5 right now. In 19.0.383 at least it seemed to be properly only calling 123.py or houdinicore.py on bootup without a file. But for 19.5, it appears to be calling houdinicore.py and THEN 456.py. Is this expected behavior in 19.5?
