Using the MATRIX DEMO building generator tool
3060 1 2-
- jamiejenssen
- 2 posts
Hi,new to the Houdini engine plugin here i'm wondering if there is any documentation for the building generator HoudiniAsset found in the city sample asset package. I've downloaded the recommended Houdini version 18.5.563 and made sure I have the licenses setup, Houdini Engine session is ready but I can't seem to get the tool to generate anything. I've looked all over for documentation but can't find much at all for this tool Any direction on the use of it would be very much appreciated thank you.
- jamiejenssen
- 2 posts
Ok so I found this other forum post and it looks like the genorator does not work if the plugin is installed in the engine directory, once I installed it into the project directory like outlined in this post things strted genorating and from there I was able to work out the tool! https://forums.unrealengine.com/t/howto-use-matrix-houdini-building-generation/526958 [forums.unrealengine.com]
