In the HEU documentation it recommends not checking in the unity_houdini.env file. Is there a recommended workflow to store environment info, such as paths to a shared HDA folder, for source control? I do not see any information on using packages, so storing the path to a source controlled package directory would have to be done by each user if the unity_houdini.env is not committed to source control.
Just to add to this: The unity_houdini.env file does not seem to work the same as a regular environment file. I've tried setting the HOUDINI_OTLSCAN_PATH, but when I use session sync to start houdini, the instance does not have the HDA's installed (it doesn't seem to scan the path set in the unity_houdini.env file).
Environment File and Packages
3052 0 0-
- Monumental
- 14 posts
