Caching Voronoi Fracture does not work
   1799   2   1
i am trying a tutorial, but if i use the filenode to cache the voronoi fracture it does not work.
the error is name attribute does not exist. it works without the filecache. i attached the file.
the file uses the name attribute to make cluster that can be attached with constraints. but the constraint from rules node does not seem to find the name attribute. when the guy in the tutorial does it, it works.
voronoi cache test.hipnc (853.3 KB)
your Filecache is set to write a Single Frame which can be used to overwrite a specific frame or something, but it will still try to load sequence, hence all other frames will be missing
what you probably want is to uncheck Time Dependent Cache and then Save To Disk
oh my god, so simple. thank you. houdini is really hard at the beginning, so many options and stuff to keep track.
