ROP Cache output using Indie
   1267   1   0
Hi
I'm having trouble executing a chain of fetch nodes in a ROP network which point to a mix of fileCache and alembic nodes. When executing the dependencies the fileCache nodes don't seem to reload themselves correctly before proceeding to the next fetch node which screws up the sim.
The fileCache nodes have "Load from Disk" enabled and running each manually will work, but it would be nice to execute through the ROP network in one batched process.
rop_caching.hiplc (637.0 KB)
On the alembic1 node, if you open the settings and switch it to execute 'node by node' instead of 'frame by frame' does that fix it?
