VCC -a [--hda-dialog-script] usage ?
   909   0   1
Hey Everyone,
Did anyone manage to make use of this vcc argument -a ?
I've been building nodes with vex and VCC for some time now. But I found the Vex Compiler Pragmas to be limiting nowadays and confusing as well for larger Parameter sets (No multiparm Block)
So I thought since VCC seems to accept a Dialog Script I tried to make one and attach it in the vcc. However when I supply the Dialog Script file to VCC the resulting hda will have Zero parameters displayed ?
Here is what I tried
dialog_script_test.vex
cvex
dialog_script_test(
	export int test = 1;
and the dialog_script_test.ui
	name "dialog_script_test"
	script "dialog_script_test"
	label "dialog_script_test"
	help {
		"dialog_script_test Help"
	inputlabel	1	"Input 1 Test"
	parm {
        name    "test"
        label   "Test"
        type    int
        default { "0" }
        range   { 0 1 }
        parmtag { "script_callback_language" "python" }
here is the vcc command I'm using
/opt/hfs19.5/bin/vcc --hda-output ~/dialogue_script_test.hda --hda-dialog-script ~/dialog_script_test.ui ~/dialog_script_test.vex
I must be doing something wrong but can't put my finger on it. However I have tried parsing the file using Houdini's included /opt/hfs19.5/bin/dsparse command but it just crashes all the time(I tried the dsparse in houdini 19.5 19 and 18.5 and they all crash) I just get segfaults even with an empty file or other example files I found on Github. So I'm unsure if my simple dialog script is actually ok.
If anyone has any insight it would be great
Thanks in advance
