Cache lost after hitting "ESC" to cancel ?
   1501   2   0
Hi there!
From time to time it happens to me in certain files that when I cancel a sim mid-sequence, that not only does it cancel the sim as intended but it also looses all cached prior frames so I can't scrub back in time. I can't track down what causes this, it seems random but is persistent once I have it in a file. Close and re-open Houdini or Windows does nothing. Even using a fresh solver does nothing to fix it. Anyone knows about this issue?
Ben
Hey Ben,
I don't know about the issue, but make sure your cache size is big enough.
Cheers
CYTE
Screenshot 2022-11-29 112656.jpg (38.8 KB)
Hi CYTE,
Thanks for your tip, it's not about the cachesize though sadly. It will cache all frames fine until I cancel the sim inbetween then they are lost. It works fine when I cache the entire sequence into RAM and not cancel at some point...
