Cupcake Project | Part 3 missing node
   2061   0   0
Good Morning!
I'm following along with the cupcake project (good stuff) and I've ran into a slight issue. On Part 3 (Icing) @ the 1:35 mark the instructor uses a "Copy Stamp" node to create a helix shape to structure the icing. From what I've found it appears this is no longer best practice and is unavailable in the current (apprentice) version. I've tried going down the "copy to points" path but not much luck. Can somebody point me in the right direction where I can achieve the same results posted in the video? Thank you in advance!
