two questions in one:
- How can I map a symbol such as § to a function, without dragging the shift key into the mapping? Because named symbol requires hitting shift and 3 on my European keyboard, in the mapping it will take both shift AND the correct symbol. After applying this does not work, either way.
- The function I am trying to remap is the Toggle Handle Geometry Detachment, because although it is mapped to ', when pressing it, the Pivot Mode gets activated (which also is being toggled with " as it should) - anyone experiencing the same, and why?
Thank you.
Hotkey mapping
1385 2 0-
- subvisor
- 4 posts
- CYTE
- 802 posts
- subvisor
- 4 posts
Thanks CYTE, I just remapped it to something else. Interestingly though, I could remap it to ! correctly, without shift being pulled in.
Maybe an improvement area for the SideFX team - that would definitely free up some important hotkey real estate.
Perhaps creating two or more fields from which the combination can be entered by inputing the single keys.
