Hi all,
I have a file that contains a texture, it's base color option is unchecked but the texture path has a file path.
it means I can't directly see the parm(basecolor_texture).
I reopen the file and get parm.isVisible(), result is True ?!
then I try click the 'use texture' option and retry parm.isVisible(), result is True
and unclick the option again, get parm.isVisible(), result is False
how can I get the correct result when just open the hip file?
Incorrect getting parm visible result
1022 0 0-
- Mojosann
- 2 posts
