Hello!
I've seen a couple of discussions on this topic around, but none of them seem to have ended up solved properly.
I'm interested in getting some OSM data into Houdini (easily done with the Labs tool) - manipulate the data however needed - and then export that data back out as an OSM or SHP file that can be successfully loaded into QGIS, with all of its attributes still intact.
There seems to be little to no info at all about exporting OSM / SHP files from Houdini, so there's so little I can work with in that regard. The closes thing I've found is HOUDARCS [github.com] custom SOPs, but the shapefile node causes multiple runtime errors I cannot seem to get rid of completely, and have that node work properly.
I'm wondering if there's someone around who has managed to successfully get OSM / SHP files out of Houdini? Thank you.
Exporting OSM / SHP files from Houdini
1116 0 0-
- nedpatru_sped
- 3 posts
