Select ONLY last points in a copy to points shape?
   2181   3   2
Hello all,
How would I select ONLY the last, outer points in a copy to points node?
For example, if I have a line, and I copy this line to a sphere using copy to points, resulting in a spikey ball--- how would I select only the outer, last points on the spikes?
Terence
There are multiple ways to do this, but perhaps the easiest way that doesn't involve VEX would be to just place the last point of your line into a group before you copy it to points.
Terence Ziegler
The Group Expression SOP has a preset called First Point of Primitive, that you can modify to return the last point instead.
Resample, output curveu attribute, group expression: @curveu==1
