flip particles collasped after turning on "density" attribut
   1110   1   0
I'm doing a lava (viscous fluid sim). Flip particles are emitted from a ball, fall down, hit the collider. And I add a uniform pop force(+Z) to pull the particles along Z axis. This works OK when the density attribute is turned off. But when I turn it on, the particles just collapse on themselves, snapped on the collider... I literaly have no clue why this happens...
PS:the particles have density attribute on themselves. The friction is low. So there must be some other reasons...
hip file:
density on.png (284.0 KB)
density off.png (306.6 KB)
lava_ask_for_help.v01.hip (1018.7 KB)
I think you should check off "solver pressure with adaptivity" if "density by attribute" was on
due to the unsupported varying density in the adaptive solver currently.
