Bra Simulation gets too stretchy
   2034   7   1
I'm trying to simulate a bra but it gets too stretchy no matter how much i crank up stiffness value. I also don't want to use attach to geometry constraint because i need it to behave as organic as possible. Any ideas would be a lot of help. Thanks!
You can use a shrinkwrap sop, use it to simulate, then use point deform
increase the constraint iterations
Stretchy behavior can be caused by lack of substeps. Increase it to 10 - 15 even 20
philippepetitpas
How do i simulate shrinkwrapped bra when it makes bra become penetrated with body mesh at the start frame? plus there's not even enough geometry after adding shrinkwrap. Am i missing something? :S
Sorry I was thinking you need to simulate a bra in the air. If it’s on a body, my solution doesn’t work
i belive that geometry will be hard to work, try to remesh it and have more even polys
try something like a triagnle or quad remsch, you are missing geomtetry to work with
