Blast node deletes edges, why?
   1118   4   1
Hi everybody,
i have a simple setup like the attachmentz shows.
My Problem is that the Blast node removes the edges from the remaining points as well.
Is that intended behaviour? Or do I use it wrong? If so, how do I Blast away only the top of the extrusion and keep
the edges at the bottom?
Any guidance is appreciated.
Regards
Matthias
Screenshot 2023-08-25 113900.png (1.7 MB)
I would suggest posting your hip file, hard to know what's happening without it.
Here's the HIP file.
test.hiplc (76.0 KB)
Try adding a Ends sop with Close U parameter set to "Open" before your blast2 node.
That's it! Thank you so much!
