I'm encountering an issue with Arnold in Solaris.
As you can see in the attached picture, the curvature node doesn't work properly when using CPU mode.
Only Curvature_Convex returns nothing.
Has anyone else experienced similar behavior?
I have attached the .hiplc file link for the reference.
https://drive.google.com/file/d/1Wy2q3f_wD2tsHfmLrAMWOh8rnUdCyegM/view?usp=sharing [drive.google.com]
If someone could take a look at it, I would greatly appreciate it.
Thanks,
Kensho
Houdini: 19.5.752
HtoA: 6.2.4.0
Arnold: 7.2.4.0
【Arnold】Curvature node does not work properly in Solaris.
1773 1 0-
- kensho.murata
- 3 posts
- beatreichenbach
- 14 posts
This was answered in the Autodesk forum [forums.autodesk.com].
Hello, this seems to be happening because USD meshes aren't double sided by default.
Try adding a mesh edit LOP and enable double-sided and it should fix the issue.
