Greetings all,
I have three questions that I am hoping someone can kindly help me with;
1. In the latest version of Houdini (19.5.752) I have noticed a small change in the way that the UV cutting mode works. I could have sworn that in previous versions, when in this mode, if you loop selected and the loop hit an already defined seam it would stop. This was an amazing functionality that I really liked because it meant that I could do my major cuts first and then the small stuff like fingers and ears and such without slicing my model into tiny bits. Now if I do a loop cut it ignores previous cuts and acts as normal. Not a deal breaker but it was a really nice perk.
2. Once I open my group select window I cannot close it. I know the hot key should be 9, but when I press 9 I just get a message in the viewport that says "quick view loaded". Not sure what is up with that.
3. Also ... what are "quick views" lol
Thanks in advance for any light any of you can shed on these mysteries.
Have a great day
B
UV cut selection mode and Group Selection Mode Question
751 0 0-
- BryanErvinBenley81
- 20 posts
