Extracting largest piece from a polygon soup based geometry?
   1526   2   0
If I want to extract the largest piece from a volume collection, the 'delete small parts' SOP only works if the geometry is polygon based. Why doesn't it work on polygon soup?
Edited by proceduralist - Oct. 11, 2023 05:00:39
small vol deletions.hiplc (319.5 KB)
the "delete small parts" node uses the connected primitive area to determine the size.
a polysoup is only one primitive per definition.
Cheers
CYTE
Edited by CYTE - Oct. 11, 2023 05:14:47
Thanks a lot. I understand now. Just checked the info and found out what you're stating.
