In Houdini, I am working with animation data to perform Fracturing, followed by an RBD simulation.
In this scene, the box visible upon opening the hip file represents the front part of a ship, which collides with a wall, causing only the impacted area to break apart.
The issue I am facing is as follows:
I am utilizing the active and deforming attributes to make the RBD simulation follow the animation path. However, upon collision with the wall, when I adjust the values of active and deforming using a sop solver within the DOP network, the constraints follow the animation path instead of the fragments.
[Solved]Issue with Constraints Following Animation Path Instead of Fragments upon Collision in Houdini RBD Simulation
1992 1 0-
- realricecakecookie
- 10 posts
- 10 posts
