"shop_materialpath" attribute added on export
   2651   2   1
It looks like Houdini is adding a "shop_materialpath" attribute whenever I export geometry as an Obj.
So when I import the geo back into another scene I have to either delete the attribute if I want Redshift to use he material path in the Geo node, or add a material SOP to override the attribute.
Is there a way to disable Houdini adding this attribute ?
Try using an attribute delete before you export to .OBJ.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
hey, thanks.
yes off course, but I was kind of hoping for a preference setting somewhere. Why default add this attribute that can only cause issues later on ?
Smells like a bug to me...
