node = hou.node("../CONTROLLER") # Get the parameters of the node parameters = node.parms() # Create an empty string to store parameter information param_string = "" # Iterate through the parameters and populate the string for param in parameters: # Check if the parameter name contains the substring "folder" if "folder" in param.name().lower(): continue # Skip this parameter param_name = param.name() # Check if the parameter has the 'label' attribute if hasattr(param, 'label'): param_label = param.label() else: param_label = "Label not available" param_value = param.eval() # Add parameter information to the string param_string += f"Parameter Name: {param_name}\n" param_string += f"Parameter Label: {param_label}\n" param_string += f"Parameter Value: {param_value}\n" param_string += "------------------------\n" return param_string
Get all parameters of a node - python
4276 3 1-
- papsphilip
- 388 posts
It seems i can access the name and value of each parameter but not the label. How can i grab the labels instead of the names?
Edited by papsphilip - Dec. 1, 2023 12:58:48
- graham
- 1926 posts
- papsphilip
- 388 posts
grahamthanks Graham!
You need to use hou.Parm.description() to get the label.
I transferred all the code to a python module.
Is there a way to take all these values and dump them inside a string parameter without a button to trigger the function?
def getparms(): hda = hou.pwd() mynode = hda.parm('mynode').evalAsString() node = hou.node(mynode) # Get the parameters of the reference node parameters = node.parms() # Create a dictionary to store parameter information param_data = {} # Iterate through the parameters and populate the dictionary for param in parameters: param_label = param.description() param_name = param.name() param_value = param.eval() # Get the type of the parameter param_type = str(param.parmTemplate().type()).split('.')[1] if param_type == 'FolderSet': continue if param_type == 'Menu': label = param.menuLabels()[param_value] index = param.menuItems()[param_value] param_value = label # Add parameter information to the dictionary param_data[param_label] = { 'name': param_name, 'value': param_value, 'type': param_type } # data = json.dumps(param_data, indent=2) # hda.parm('getparameters').set(data) return param_data
right now i am returning the data and then in a string parameter i am calling the function like this
import json data = hou.pwd().hm().getparms() mydata = json.dumps(data, indent=2) return mydata
is there better way?
- papsphilip
- 388 posts
stumbled across another issue where node.parms() didn't quite read tuples correctly. so this was my solution if anyone is interested or knows a better way:
next steps would be to also include other types of parameters like ramps and multiparms but also keyframes!
Also making it more general, for example i exclude expressions for the purposes of my project but ideally they should be stored and set as well.
Another useful feature would be to add a auto populating ordered menu to read all stored data so that we can choose more easily without opening windows browser etc.
Last but not least this code needs more error checking. currently i dont print anything to the console or inside some string.
def getparms(): hda = hou.pwd() mynode = hda.parm('mynode').evalAsString() node = hou.node(mynode) parms = node.parms() tmp = [] values = [] names = [] type = [] labels = [] indexes = [] param_data = {} for parm in parms: # check if the parameter is inside a specific folder. This is in case i want the parms of the HDA itself # and want to exclude the interface for dealing with exporting json parameter files if 'Export Presets' in parm.containingFolders(): continue # Skip parameters with expressions try: exprlang = parm.expressionLanguage() if exprlang: continue except hou.OperationFailed: exprlang = "None" t = str(parm.parmTemplate().type()).split('.')[1] # Here is the part where i don't use parm.eval() to get the values but instead # get the everything as tuples and store all parameter names in a tmp array which we read later to get the values p = parm.tuple().name() n = parm.name() l = parm.description() # Skip Folder parameters - not folder contents if t == 'FolderSet': continue # if its a Menu we need the index to read it back later if t == 'Menu': index = parm.menuItems()[parm.eval()] else: index = -1 tmp.append(p) names.append(n) type.append(t) labels.append(l) indexes.append(index) # Getting the correct values ---- remove duplicates and flatten array tmp_values = [item for index, item in enumerate(tmp) if item not in tmp[:index]] for i in tmp_values: v = node.evalParmTuple(i) values.append(v) flat_values = [item for sublist in values for item in sublist] count = 0 for name in names: if type[count] == 'Menu': index = indexes[count] # Add an extra key 'index' with the value from the variable index param_data[name] = { 'label': labels[count], 'value': flat_values[count], 'type': type[count], 'index': index } else: # Add parameter information to the dictionary without the 'index' key param_data[name] = { 'label': labels[count], 'value': flat_values[count], 'type': type[count] } count += 1 return param_data
Edited by papsphilip - March 8, 2024 05:18:17
