Auto retopology quad remesh
5639
2
1
kskovbo
Dec. 4, 2023 8:53 a.m.
I've been certain around a bit, but could not find a definitive answer. I am after a auto retopology tool akin to the one found in Maya, Zbrush, Blender, etc.. - E.g NOT the built in "Remesh" node.
The only one I've found for Houdini is Quadmesher by Exoside and sits behind a paywall.
https://www.sidefx.com/tutorials/sidefx-labs-exoside-quadremesher/ [
www.sidefx.com ]
Is that correct or am I missing a node in Houdini? What is everyone's solution for this?
protozoan
Dec. 4, 2023 8:59 a.m.
If you have access to Houdini 20, you can try the new quadremesh sop. (It's still in its infancy, but works for organic surfaces). Other than that: Exoside.
Martin Winkler
kskovbo
Dec. 4, 2023 12:17 p.m.
Yep ok I see. I do have Houdini 20, but still using 19.5 due to Renderman compatibility. I'll check out the new QuadRemesh node in 20. Thank you!
