Errors showing up when project reopened on another machine
   1065   2   0
I followed the destruction tutorial on a laptop. After that I wanted to render it on my pc, so I zipped the folder and posted it to my pc. After reopening it on the pc, there's some errors in the stage say: "Unable to find layer file: C:/Users/2020/Documents/Houdini ".
And the scene graph content is missing too.
How can I make this right?
Double check and make sure your File Path(File Pattern) is referencing what it's supposed to be referencing and also double check the Primitive Path that the correct thing is being sourced from the scene graph. Perhaps if you are using $HIP, the files it's looking for aren't where it's expecting or perhaps the Scene Graph has changed somehow. Those would be my initial guesses to double check.
tinyT
You're right. The file path is truncated by the blank space in the middle. After renaming the home folder everything works well.
