How to bake texture to other uv in Copernicus
2759 2 2-
- CoreSign
- 31 posts
- GrahamDClark
- 309 posts
Use a COPs out of rasterized UV map and then labs maps baker which is non-procedural, or,
Inside of COPs, defer baking and keep procedural, use uvsample() in SOPs or COPs: wrangle COP:
@C = uvsample(1, "uv_new", "uv", v@P);
Will make a shorter vid showing just this, but for now its in here:https://youtu.be/nqpovSR1nJ8?si=YIrM2tnA_5AX9fEo&t=1190 [youtu.be]
That gets slow live, and if your UVs are static no need to keep it live, so bake it by inserting a ROP save image after that wrangle COP, then file COP it back in to you COP network and pipe that into a texture sample COP to put your texture into that other uv, and then ROP image render that texture
Edited by GrahamDClark - July 25, 2024 14:01:49
Yay! I'm certified! https://media.sidefx.com/uploads/accounts/badges/certified_instructor_badge_AkLiM3h.svg [media.sidefx.com]
- CoreSign
- 31 posts
GrahamDClarkWork like a charm,Thank you so much for your help!
That gets slow live, and if your UVs are static no need to keep it live, so you can insert a ROP save image after that wrangle COP, then file COP it back in to you COP network and pipe that into a texture sample COP to put your texture into that other uv, and then ROP image render that texture
