So im tryng to keep a fractured object in the air but at the same time i'm tryng to brake it apart using a field force.
this allows me to paint witch “area” wil be blown away by the force.
now i try'd 2 things i first i used point contrainths to keep it steady but the all of the sudden all the peices acted as one single object.
so then i tryd gluing it to another object.
but it now seams the force has no influence on the glue !:>???
is this a BUG ?
or am i doing somethen wrong ??
Glue fieldForce
4761 2 0-
- Tamis
- 58 posts
- craig
- 557 posts
I don't think you can have things be broken apart (that is, have glue bonds be broken) simply with forces. You have to have impacts, which come from actual objects colliding with your object.
So if you want to blow something apart like that, you'll have to hit it with one or more objects (call them force objects), which themselves can be motivated by the field force. Then when you render the result, just don't show the force objects.
- Tamis
- 58 posts
