That made it difficult to use the setup-script provided by SideFX in the Houdini installation, so I decided to translate the existing Bash script to Fish.
Which I want to share with everyone here, in case someone else might need it:
# Environment setup script for Houdini.
# To use this script you should "cd" to the hfs directory where this
# script is located and "source" it into your bash shell or from your
# .profile script.
# Alternatively you may copy this script, remove the first if
# statement and change the setting of the "HFS" variable to be
# the location of your installed Houdini hfs directory.
# Note that this script modifies your search path by inserting the
# Houdini bin directory at the beginning. It may also sets the environment
# variable LD_LIBRARY_PATH which is used to search for runtime libraries.
# To run the script in quiet mode, specify the "-q" option on the
# command line.
if [ ! -d houdini -o ! -d dsolib -o ! -d bin ]
echo "You must cd to the Houdini installation directory before"
echo "sourcing this script. This allows the script to determine"
echo "the installed location."
else
set -gx HFS "$PWD"
# The following are some handy shortcuts:
set -gx H "$HFS"
set -gx HB "$H/bin"
set -gx HDSO "$H/dsolib"
set -gx HH "$H/houdini"
set -gx HHC "$HH/config"
set -gx HHP "$HH/python3.11libs"
set -gx HT "$H/toolkit"
set -gx HSB "$HH/sbin"
# The following is used as the generic /tmp path. This is also
# set on Windows to the temporary directory, so can be used for
# system independent .hip files.
set -gx TEMP /tmp
# Look for java.
if [ "$JAVA_HOME" = "" ]
# Check in PATH first
set -l d (which java 2>&1)
if [ "$status" = "0" ]
set -gx JAVA_HOME (echo "$d" | sed 's/\/bin.*//g')
else
for dir in /usr/local /usr/local/java2 /usr/local/java /opt /usr /usr/java2 /usr/java
if [ -d "$dir" ]
set -l d $(find "$dir" -maxdepth 3 -path "*/bin/java" -printf "%h\n" 2> /dev/null | head -1 | sed 's/\/bin//')
if [ "$d" ]
set -gx JAVA_HOME "$d"
break
end
end
end
end
end
# We only need to set LD_LIBRARY_PATH if the environment also uses it. This
# makes sure HDSO is always searched first. Houdini binaries are built with
# DT_RUNPATH set so it only gets used after LD_LIBRARY_PATH.
if [ "$LD_LIBRARY_PATH" != "" ]
set -gx LD_LIBRARY_PATH "$HDSO:$LD_LIBRARY_PATH"
end
# If the java binary exists but cannot be found, then add JAVA_HOME
# to PATH. Otherwise, only add HB and HSB to PATH.
set -l java_path (which java 2>&1)
set -l which_java $status
if [ "$JAVA_HOME" = "" -o "$which_java" = "0" ]
set -gx PATH "$HB:$HSB:$PATH"
else
set -gx PATH "$HB:$HSB:$JAVA_HOME/bin:$PATH"
end
set -gx HOUDINI_MAJOR_RELEASE 20
set -gx HOUDINI_MINOR_RELEASE 5
set -gx HOUDINI_BUILD_VERSION 304
set -gx HOUDINI_VERSION "$HOUDINI_MAJOR_RELEASE.$HOUDINI_MINOR_RELEASE.$HOUDINI_BUILD_VERSION"
# Build machine related stuff
set -gx HOUDINI_BUILD_KERNEL "4.18.0-513.18.1.el8_9.x86_64"
set -gx HOUDINI_BUILD_PLATFORM "Red Hat Enterprise Linux release 8.9 (Ootpa)"
set -gx HOUDINI_BUILD_COMPILER "11.2.1"
# This only applies for linux systems
set -gx HOUDINI_BUILD_LIBC "glibc 2.28"
if [ $statusprompt ]
if [ "$1" != "-q" ]
echo "The Houdini $HOUDINI_VERSION environment has been initialized."
end
end
# These environment variables are no longer supported.
set -gx HIH "$HOME/houdini$HOUDINI_MAJOR_RELEASE.$HOUDINI_MINOR_RELEASE"
set -gx HIS "$HH"
end
The original Bash script is from a 20.5.304 installation.
