MaterialX Switch node limitation
   1622   2   0
Hi people!
How can I connect more than five textures to MtlX Switch node?
From Houdini manual: "Pass on the value of one of five input streams, according to the value of a selector parameter."
I have an integer attribute (0-9) to switch between the textures, but Switch node have only five inputs.
You'll have to chain switch nodes and do some math to modulate the index.
Okay, just solved it. For small setup <=10 you can use two Switch nodes connected to IfGreater node.
