fluid flows only 1 frame, how to emit it continuously?
   1122   2   0
Hello
I made a sphere which moves and which must emit liquid continuously, but the liquid flows in the first frame only. I probably forgot to check something somewhere, but where (file joined)
Edited by MrCedric - Aug. 29, 2024 12:01:24
Flow.hipnc (1007.1 KB)
FLow 1.JPG (266.7 KB)
FLow 2.JPG (215.0 KB)
With your current setup, you need to put the source particles in a point group called "particles".
You can use the sop node flip dop source to more easily set up a flip source if you're using the dop workflow. Or without changing your sop setup at all, you can just use a pop source inside the dopnet rather than a volume source and it will work as is.
edit: you can also just clear the group name from the volume source dop under the particles tab
Edited by freshbaked - Aug. 30, 2024 11:21:07
Great, thank you very much,it works now
