Get/Set values of USD camera via Python?
   1826   4   0
I'm quite new to the "stage" stuff in Houdini so forgive me if this is obvious.
How would I get/set the values of a camera in the usd/stage context (vop?) at specific times? The below snippet seems to work to get the matrix, but the "time" parameter of ComputeLocalToWorldTransform does not seem to do anything. Do I need to get an "animated" stage first somehow? And what about setting values at specific times for camera?
import hou
from pxr import Usd, UsdGeom
node = hou.selectedNodes()[0]
primpath = node.parm("primpath").evalAsString()
stage=node.stage()
prim = stage.GetPrimAtPath(primpath)
xform = UsdGeom.Xformable(prim)
wm = xform.ComputeLocalToWorldTransform(0)
print(wm)
Edited by sbjork - Jan. 27, 2025 06:18:55
Drop down a Cache LOP before using your script and make it cache desired frame range, or the whole timeline.
Edit: On second thought, no, simply set the "Frame Range/Subframes" tab on your camera to "Sample Frame Range" instead.
After making that one change your code started working for me.
Edited by alexmajewski - Jan. 27, 2025 12:51:16
Thanks @alexmajewski, works well!
Any suggestion for setting values, i.e translate or focal length (at different times).
I tried node.editableStage but it returns None. Not sure if that is the correct way though.
Sorry, my mistake, didn't realize it used the same syntax as other nodes via
node.parm("tx").set
All good.
node.parm("tx").set
Not exactly the solution I expected, but hey, if it works it works
From what I understand, the stage of nodes is locked most of the time. It is unlocked and editable under certain conditions, like when using Python Script lop on itself with stage=hou.pwd().editableStage().
If you happened to end up with an editable stage somehow, here's how you could set those attributes:
focal_len = prim.GetAttribute("focalLength")
focal_len.Set(2.0, 10) # sets 2.0 at time sample 10
focal_len.Set(5.0, 30) # sets 5.0 at time sample 30
