Hi, I have Houdini 20.5.487 py3.10 running on Ubuntu 22.04. I can't get it to open Houdini with any other user than root. I tried changing permission and ownership of the hfs dir but that didn't help. I should say, I'm new to Linux.
This is what I get in terminal
Could not find scene mouse modifier file: SceneMouseModifiers
Unrecognized modifier key token: scene.handle.floor.mirror
Unrecognized modifier key token: scene.handle.rotate.inc_snap
Unrecognized modifier key token: scene.handle.common.scale_delta
Unrecognized modifier key token: scene.handle.orientknob.lock_axis
Unrecognized modifier key token: scene.selector.plane.fullspec.pick_normal
Unrecognized modifier key token: scene.selector.plane.quickspec.align_only
Unrecognized modifier key token: scene.selector.plane.quickspec.move_only
Unrecognized modifier key token: scene.selector.plane.quickspec.point_at
Unrecognized modifier key token: scene.selector.plane.quickspec.sec_point_at
Unrecognized modifier key token: scene.selector.plane.quickspec.sel_point_at
Unrecognized modifier key token: scene.floor.xy
Unrecognized modifier key token: scene.floor.h
Unrecognized modifier key token: scene.common.extend
Unrecognized modifier key token: scene.state.view.fast_modifier
Unrecognized modifier key token: scene.state.view.slow_modifier
Unrecognized modifier key token: scene.handle.bbox.mirror
Unrecognized modifier key token: scene.handle.bbox.uniform
Unrecognized modifier key token: scene.handle.btube.mirror
Unrecognized modifier key token: scene.handle.btube.uniform
Unrecognized modifier key token: scene.handle.crosshair.scope
Unrecognized modifier key token: scene.handle.crop.mirror
Unrecognized modifier key token: scene.handle.crop.restrict
Unrecognized modifier key token: scene.handle.domain.mirror
Unrecognized modifier key token: scene.handle.domain.copy
Unrecognized modifier key token: scene.handle.hose.group
Unrecognized modifier key token: scene.handle.hose.uniform
Unrecognized modifier key token: scene.handle.ikpivot.lock_click
Unrecognized modifier key token: scene.handle.isosegment.extend
Unrecognized modifier key token: scene.handle.pill.mirror
Unrecognized modifier key token: scene.handle.translate.inc_snap
Unrecognized modifier key token: scene.handle.slider.mode
Unrecognized modifier key token: scene.handle.motionpath.insert
Unrecognized modifier key token: scene.handle.motionpath.delete
Unrecognized modifier key token: scene.handle.motionpath.move_key
Unrecognized modifier key token: scene.handle.scale.inc_snap
Unrecognized modifier key token: scene.handle.mousewheelbump.slow
Unrecognized modifier key token: scene.handle.mousewheelbump.fast
Unrecognized modifier key token: scene.handle.mousewheelradius.slow
Unrecognized modifier key token: scene.state.brush.brush_radius
Unrecognized modifier key token: scene.state.brush.brush_radius_wheel_slow
Unrecognized modifier key token: scene.state.brush.stencil_clear
Unrecognized modifier key token: scene.state.capturelayerpaint.select
Unrecognized modifier key token: scene.state.edit.brush_radius
Unrecognized modifier key token: scene.state.edit.brush_radius_wheel_slow
Unrecognized modifier key token: scene.selector.join.flip_click
Unrecognized modifier key token: scene.state.stroke.cursor_radius
Unrecognized modifier key token: scene.state.stroke.cursor_radius_wheel_slow
Unrecognized modifier key token: scene.selector.uvpelt.hint_click
Unrecognized modifier key token: scene.state.bone_create.split
Unrecognized modifier key token: scene.state.bone_create.parent
Unrecognized modifier key token: scene.state.capture_weights.bone_toggle
ERROR: Couldn't open resource file "resources" (No such file or directory)
Can't open dophints.cmd
Error running event handler:
File "labs::Lop/karma::2.0, ViewerStateModule", line 18, in <module>
File "/opt/hfs20.5.487/python/lib/python3.10/site-packages-forced/shiboken2/files.dir/shibokensupport/feature.py", line 139, in _import
return original_import(name, *args, **kwargs)
ModuleNotFoundError: No module named 'ParseExrMetadata'
File "labs::Lop/karma::2.0, opdef:/labs::Lop/karma::2.0?ViewerStateInstall", line 1, in <module>
File "/opt/hfs20.5.487/houdini/python3.10libs/viewerstate/utils.py", line 1007, in register_pystate_embedded
raise ViewerStateException(
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/labs::Lop/karma::2.0?labs::Lop/karma::2.0
File "labs::Sop/wfc_sample_paint, ViewerStateModule", line 6, in <module>
ModuleNotFoundError: No module named 'sidefx_stroke'
File "labs::Sop/wfc_sample_paint, opdef:/labs::Sop/wfc_sample_paint?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/labs::Sop/wfc_sample_paint?labs::Sop/wfc_sample_paint
ERROR: Couldn't find 'FUSE_ColorOptions.ui' for reading. Looked in:
/opt/sidefx_packages/SideFXLabs20.5/config/Applications
/opt/hfs20.5.487/packages/sculpt/config/Applications
/opt/hfs20.5.487/packages/kinefx/config/Applications
/opt/hfs20.5.487/packages/apex_cop/config/Applications
/opt/hfs20.5.487/packages/apex/config/Applications
/opt/hfs20.5/config/Applications
Can't load the default font specification.
resources.std is either missing or specifies
an unknown font for the DefaultFont.
Thank you very much in advance!
Houdini run on root but not other user
1372 7 1-
- abhassan81
- 9 posts
- alexmajewski
- 109 posts
- abhassan81
- 9 posts
- alexmajewski
- 109 posts
What is the output of your
Here's mine that works without issues:
If I'm not mistaken, the last
ls -ld /opt/hfs20*? This command will show your permissions. (use -lto check the contents of that folder)Here's mine that works without issues:
drwxr-xr-x. 10 root root 4096 Dec 26 17:44 /opt/hfs20.5.445
r-xgrants anyone permission to read and execute.
Edited by alexmajewski - Feb. 4, 2025 17:05:43
- abhassan81
- 9 posts
- alexmajewski
- 109 posts
- abhassan81
- 9 posts
- abhassan81
- 9 posts
